Match Analysis: Cadiz vs Alaves
[Bild: Cadiz-vs-Alaves.png]
Key Stat: Looking at the last 7 matches involving Cadiz, there were low goal totals (under 2.5 goals) in 7 out of 7 matches.
Check out the latest and most exciting hot football tips here football predictions uk
Goal Prediction: Based on the analysis of the past 10 head-to-head matches, the last 10 matches of Cadiz, the recent 5 matches of Cadiz at home, the last 10 away matches of Alaves, and 7 out of the last 10 matches of Alaves having 2 or fewer goals scored, it's likely that the clash between Cadiz and Alaves at Nuevo Mirandilla will likely result in 2 or fewer goals.
Head-to-Head Analysis: Cadiz vs Alaves Recent history indicates that in the last 6 matches as visitors at Nuevo Mirandilla stadium, the team coached by Luis Garcia Plaza won 2, drew 2, and lost 2 matches. Out of these 6 matches, 5 ended with 2 or fewer goals. In the 2 most recent visits, Alaves won 1 and lost 1. In the 12 previous encounters, Cadiz won 4, drew 6, and lost 2 matches, with 10 out of 12 matches having 2 or fewer goals. Considering the last 4 recent matches between Cadiz and Alaves, Cadiz won 2, drew 1, and lost 1.
Form Analysis: Cadiz vs Alaves Cadiz hasn't won 6 out of their last 10 matches, and also hasn't won 3 out of their last 5 matches. At home, Sergio Gonzalez's team has failed to win 6 out of their last 10 matches, but managed to win 3 out of their last 5 matches. Alaves also hasn't won 6 out of their last 10 matches, but has won 3 out of their last 5 matches. Playing away, Luis Garcia Plaza's team hasn't won 8 out of their last 10 matches, and hasn't won 4 out of their last 5 matches.
For Tuesday's matches, our experts have identified several tips 1x2 tips that offer excellent value and could help you boost your bankroll.
Asian Handicap Form Analysis: Cadiz vs Alaves Cadiz hasn't won the Asian handicap in 7 out of their last 10 matches, including not winning in 4 out of their last 5 matches. At home, Sergio Gonzalez's team hasn't won the Asian handicap in 6 out of their last 10 matches, but won the Asian handicap in 3 out of their last 5 matches. Alaves has won the Asian handicap in 7 out of their last 10 matches, with 3 wins out of their last 5 matches. Playing away, Luis Garcia Plaza's team has won the Asian handicap in 5 out of their last 10 matches, and has won 3 out of their last 5 matches.
Over/Under Form Analysis: Cadiz vs Alaves Based on the over/under odds, Cadiz has had under 2.5 goals in 8 out of their last 10 matches, including 5 out of their last 5 matches. At home, Sergio Gonzalez's team has had under 2.5 goals in 7 out of their last 10 matches, including 4 out of their last 5 matches. Alaves has had over 2.5 goals in 6 out of their last 10 matches, with 3 out of their last 5 matches having over 2.5 goals. Playing away, Luis Garcia Plaza's team has had over 2.5 goals in 5 out of their last 10 matches, and 3 out of their last 5 matches.
MATCH INFORMATION Stadium: Nuevo Mirandilla. EXPECTED LINEUPS Cadiz: Ledesma, Carcelen, Fali, Mbaye, J Hernandez, Sobrino, Escalante, Alcaraz, Machis, Roger, Ramos. Coach: Sergio Gonzalez. Alaves: Sivera, Marin, Sedlar, Abqar, Duarte, Guevara, Blanco, Alkain, Guridi, Rioja, De la Fuente. Coach: Luis Garcia Plaza.
Prediction: Cadiz (-1/4).
Goal Prediction: Under 2.5 goals.
Score Prediction: 1-0.
WinTips has a guide that can get you started in just 5 minutes https://wintips.com/fun88-deposit-guide-in-just-5-minutes/
