Analysis of the match Spartak Trnava vs. FK Auda Riga
[Bild: poster]
Key point: In the last 8 away matches of FK Auda Riga, the majority have resulted in "Under" (fewer goals scored).
Match result analysis:
With better form, FK Auda Riga is likely to win easily in the match against Spartak Trnava.
If you're tired of relying on your gut for soccer predictions, try out computer soccer tips for data-driven insights into upcoming matches.
Specifically, FK Auda Riga has won 6 out of the last 9 away matches and won 5 out of the last 9 matches overall.
On the other hand, the team playing at the Anton Malatinsky Stadium has lost 4 out of the last 5 matches, 4 out of the last 6 home matches, failed to win in 8 out of the last 10 matches, and failed to win in 4 out of the last 5 home matches.
This indicates that it will be highly likely for FK Auda Riga to win against Spartak Trnava in this away game.
Goal prediction:
Based on the analysis of the last 5 matches of FK Auda Riga and the last 10 away matches of FK Auda Riga, there have been 2 or fewer goals scored in 8 out of the last 10 away matches.
Therefore, the match between Spartak Trnava and FK Auda Riga at the Anton Malatinsky Stadium is likely to have less than 3 goals scored.
Form analysis for Spartak Trnava vs. FK Auda Riga:
Spartak Trnava has not won in 7 out of their last 10 matches and has not won in their last 5 matches.
At home, the team led by coach Michal Gasparik has not won in 7 out of their last 10 matches and has not won in their last 3 matches.
FK Auda Riga has not won in 8 out of their last 10 matches and has not won in their last 5 matches.
On away matches, FK Auda Riga has not won in 6 out of their last 10 matches and has not won in their last 3 matches.
Asian handicap form analysis for Spartak Trnava vs. FK Auda Riga:
Looking for real tips 1x2 to take your betting game to the next level.
Spartak Trnava has not won in 8 out of their last 10 Asian handicap matches, and they have not won in 3 out of their last 5 matches.
At home, the team led by coach Michal Gasparik has not won in 7 out of their last 10 Asian handicap matches and has not won in 4 out of their last 5 matches.
FK Auda Riga has won 5 out of their last 10 Asian handicap matches, but they have not won in 3 out of their last 5 matches.
On away matches, FK Auda Riga has won in 6 out of their last 10 Asian handicap matches and won in 3 out of their last 5 matches.
Total goals form analysis for Spartak Trnava vs. FK Auda Riga:
Based on the over/under goal statistics, Spartak Trnava has had 7 out of their last 10 matches resulting in "Under," but they had 3 out of their last 5 matches resulting in "Over."
At home, the team led by coach Michal Gasparik has had 5 out of their last 10 matches resulting in "Over," and 3 out of their last 5 matches resulting in "Under."
FK Auda Riga has had 7 out of their last 10 matches resulting in "Under," and 4 out of their last 5 matches resulting in "Under."
On away matches, FK Auda Riga has had 8 out of their last 10 matches resulting in "Under," and 3 out of their last 5 matches resulting in "Under."
Prediction:
Choose: FK Auda Riga (+1 1/2) (meaning that FK Auda Riga is favored by 1 1/2 goal in the Asian handicap betting).
Total goals prediction: Under.
Score prediction: 1-0 (indicating that the match is likely to end with a score of 1-0 in favor of FK Auda Riga).
Check out this comprehensive guide on what is cricket and how to get started with cricket betting for new players https://wintips.com/what-is-cricket-cricket-betting-guide-for-new-players/
