Reasons for selling shares
Investors often buy a company's share because it has a competitive advantage that puts it at the forefront of competitors in the stock market. However, if the situation turns upside down and the company loses its competitive advantage, this means that investors will not continue to hold the share, which will only increase the situation in loss.
طريقة بيع الاسهم في الراجحي
Once investors realize the fact that the company is deteriorating or going in the wrong direction, the stock's performance in the stock market will inevitably decline, which means that it is better to follow the method of selling shares before it is too late and with less losses to avoid the woes of large losses that will inevitably become a reality once the stock price declines to reflect the company's declining performance.
If the stock decline is the result of a temporary shock in the company's performance while the fundamentals are still solid, this temporary setback may represent a good opportunity to buy more of the stock when its price declines and before it rises again, so the assumptions on which the investor bases his investment decisions must be the result of a study and awareness of the size of the company and its ability to overcome temporary crises and recover.
Another reason that may push investors to sell or abandon shares is the emergence of investment opportunities better than current shares, as the stock market always shows investment opportunities that cannot be missed, represented by excellent shares available at prices that may not be repeated again, and in the event that the investor does not have the necessary liquidity to seize this opportunity, he may find himself forced to liquidate part of the stock portfolio in order to be able to seize the stock that he sees as its growth prospects may be strong enough to compensate for the shares he abandoned.
