Advantages of Harmonic Analysis
Discovering geometric patterns: Harmonic analysis helps traders discover specific geometric patterns such as shell, butterfly, and golden wing patterns. Similarly, these patterns provide signals about the potential reversal of the price trend.
Identifying entry and exit points: Harmonic analysis provides signals to identify potential trade entry points when the patterns are completed, as well as identifying potential target levels and stop points.نموذج هارمونيك
Using Fibonacci ratios: Harmonic analysis is largely based on Fibonacci ratios, which are a powerful tool for identifying correction and extension levels in the price. Accuracy in forecasts: When the harmonic pattern is completed and its points coincide with the Fibonacci ratios, the signals can be accurate and provide strong forecasts of price action.
