How to Play Cribbage | Setup
How to Play Cribbage | Setup the Cribbage game requires a Cribbage board in order to keep the scores. It is basically a board that has 4 rows and pgs168 each row has 30 holes in it. A middle panel splits these 4 rows are split into 2 sets. The board is placed between the players. All players take 2 pegs of the same color. So when a player scores, they have to move a peg along the side of this board. Every hole gives 1 point. Players have to decide before the game begins, the target score. It can be either of the two –
1.  61 Points = Once Around
2.  121 Points = Twice Around
