Kluster Krystals Megaclusters
Kluster Krystals Megaclusters The third game in the Megaclusters series is Kluster Krystals Megaclusters, this is a tiki-themed slot (with a bit of a space-age twist) pg slot game that's a little bit different to the others. The game grid always stays the same size, however, when winning clusters are registered symbols (that are broken down into four) physically grow in size as a segment of the quarter is added. This high volatility slot has an RTP of 96.49% and can see players win 5,000x their stake.
